locked steering wheel - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 05-14-2012, 08:27 AM Thread Starter
lets me start off with I have no idea where this should really be posted at..
Ok my girls 2004 6i hatchback, 2.3L, tiptronic auto has been recently having the steering wheel lock constantly. You can literally pull straight into a parking spot, shut the car off without messing with the wheel and it lock up. Normally this wouldn’t be a problem but its getting to the point where you have to fight the steering wheel to get it to unlock.
This isn’t the normal turn the wheel one way and hold to turn to key to unlock issue. This is really firm and pretty much nearly takes both hands to turn the wheel. When this first started happening it was fairly easy like normal to unlock but as time progresses. The wheel is getting harder and harder to unlock.
Anyone have any ides on what this is and how to go about fixing it?
StealthWyvern2 is offline
post #2 of 5 (permalink) Old 05-14-2012, 08:42 AM
Kware22's Avatar
Quoted: 57 Post(s)
Groans: 14
hmm. so the wheel isn't fully turned when it locks up?
2009 Mazda 6i
Blacked out emblems, 35w 6000k HIDs, 2 MTX Terminator 12's, 1200w Kenwood Class D mono amp, Painted headlight internals, Megan Racing M-Spec II muffler, 19" Stance SC6 wrapped in 225/35/19 Federal 595s, H&R Lowering springs, red tinted tails, red interior led swap, rising sun engine cover, red calipers;
Soon to come
CS Intake, vinyl roof, tinted windows, D2 coils, vinyl wrap, spectrum silver wheels, fogs;
Kware22 is offline
post #3 of 5 (permalink) Old 05-14-2012, 12:25 PM
austinairport's Avatar
Groans: 42
How much fluid is in your power steering reservoir? Check that first. If the power steering pump is dead, it would make the steering extremely heavy, especially at low speeds. Check fluid level first, then report back.
2004 Mazda 6i ATX -Ksport - Magnaflow - Motegi -
austinairport is offline
post #4 of 5 (permalink) Old 05-14-2012, 01:34 PM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 604 Post(s)
Groaned at 7 Times in 7 Posts
iTrader: 2 reviews
Ignition switch assembly slides into the collar around the steering column. Between the switch and the column is a bolt that locks the wheel/column into place when the key is removed. Not dissimilar from a dead bolt on a door.
Sounds like that locking assembly has gotten dirty and is sticking, or may even have return spring issues.
When you turn the key in the ignition switch, a space opens for that bolt to be pulled back by a return spring. If is dirty/gritty, or if return spring is not correct or borked, then the bolt will not behave.
The problem will likely continue to get worse.
It's not overly complex to dissassemble & clean if you've done ignition switch work before, but if you haven't ever done anything like that before, or are not mechanically inclined, I suggest taking it to a locksmith and letting them have at it.
Was a Mazdaspeed6 GT #3476 TiGray slicktop
2009 BMW 135i - double the turbos, double the fun!
E82.N54 / Steptronic w/ Alpina B3 flash / Berk Street exhaust / MHD 1+
340 hp / 371tq
TiGraySpeed6 is offline
StealthWyvern2 (05-14-2012)
post #5 of 5 (permalink) Old 05-14-2012, 09:45 PM Thread Starter
Thanks, Ill have to give that a look when i get some time to tear into it. That sounds like a more then reasonable issue. I was thinking it was something in the colum more then likely as you can come to a complete stop in the middle of the road, shut the car off, and have the same issue as if you turned the wheel to lock it.
The car steers fine even at low speeds and doesnt have a power steering issue nor leaks fluid, the fluid level is also fine, and it doesnt moan when turning the wheel.
