Could it be the PVC problem or something else? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 21 (permalink) Old 07-02-2012, 09:11 AM Thread Starter
KWhale's Avatar
Ok. Just had it replaced along with the hose and gaskets. Parts were $110. Labor was $200 (friend rate for about 5 hours) because he also fixed my clutch pedal. I think I made off pretty well money-wise. The valve did pour oil out when it was taken out and so far after a day of driving the oil seems to be right where it was when I filled it. Lets hope this continues throughout the week.
2003 Mazda 6i MTX Glacier Silver
KWhale is offline
post #12 of 21 (permalink) Old 10-31-2012, 12:15 AM Thread Starter
KWhale's Avatar
Was still losing oil (slower rate) after everything was changed. Went to change my spark plugs and found quite a bit of oil in the plug holes and the plugs were black... Changed valve cover gasket and oil seems to be staying consistent. Anyone else have any other suggestions on where it could be going? No black buildup on the rear bumper above the tail pipes either.
KWhale is offline
post #13 of 21 (permalink) Old 10-31-2012, 01:40 AM
Final Impact's Avatar
Quoted: 532 Post(s)
Groaned at 4 Times in 4 Posts
Cars that drip while running usually coat the floor pan and at highway speed will tag the bumper and rear of the car with oil spots. If its not there, its on the ground somewhere so you need to look until you find it (up on a lift???)!
How often do you all change your oil anyway? They can be burning it; and if so change it more often and rev it a tad more, add some Techron fuel cleaner at least three times a year and bump the OCI to 4K max, this can help reduce oil consumption.
V6 repair info here:
Final Impact is offline
post #14 of 21 (permalink) Old 10-31-2012, 11:07 PM Thread Starter
KWhale's Avatar
Dry as a bone. I change between 3k to 5k (depends on weather, no garage). A friend at the ford dealership in town wants to look into it. When it goes in, i'll post more info.
KWhale is offline
post #15 of 21 (permalink) Old 02-25-2013, 05:11 PM
KWhale: I have a 2003 6i with 116k miles with the same issues you are having, including the surging part when first starting up. I'm taking my car in tomorrow to have this looked at. But, did you ever resolve what was happening with yours? I sure would like to know if you came with a solution before I start spending the money for them to figure it out.
arock is offline
post #16 of 21 (permalink) Old 02-25-2013, 07:05 PM Thread Starter
KWhale's Avatar
Still not sure what it is. Changed my oil using quaker state 5w-20 and a bottle of Lucas Oil Stabilizer. Seems to have slowed it quite a bit. Not putting as much in as I use to.
KWhale is offline
post #17 of 21 (permalink) Old 02-25-2013, 07:53 PM
OK, thanks. So you think that replacing the PCV valve might've helped slow down the oil consumption a bit? I'll pass this along to my mechanic about looking into that.
arock is offline
post #18 of 21 (permalink) Old 02-25-2013, 08:14 PM Thread Starter
KWhale's Avatar
Yeah and they are known for going bad. the valve and hose are pretty cheap at the dealership too.
KWhale is offline
post #19 of 21 (permalink) Old 10-02-2014, 03:17 PM
speed914's Avatar
Quoted: 6 Post(s)
Send a message via AIM to speed914
Bump
Any of you guys figure this out from your mechanics?
I'm going through 1-2 quarts per week (350miles) and same issues.
I did have a hole in the internal valve cover gasket, leaking oil into wells 2 and 3 but replaced that and thought all would be fine. still burning the same amount tho..
Going to hit the PVC this weekend but doubt that is the issue.
2005 Mazda 6i Sport Glacier Silver ATX
Apexcone 6000k HIDs, PIAA 7500K Spark Blue H3, F5 Fujita Intake, Remote Car Starter, Lotek Gauge Pod, ProSport Premium Series Oil Pressure and Oil Temp Gauge, ProSport Performance Air/Fuel Ratio Gauge, ScanGauge II, CPE battery tray, Odyssey 680, Tein Hood Dampers, grounding kit, clear side markers, Mazda3 2.0l Spin-on Oil Filter conversion, G2Performance Caliper paint, All weather mats, ALL hyper white LEDs, stubby antenna
speed914 is offline
post #20 of 21 (permalink) Old 11-08-2014, 12:15 AM
speed914, did you end up replacing the PCV valve?
I started losing 1 quart about every thousand miles at 125k. Now I'm at 150k and the problem is suddenly getting worse-- the last quart I added was only 300 miles from when it was last full; prior to that, 500 miles.
No noticeable smoke or oil on ground when parked. The car is running great, other than the oil consumption.
I had the valve cover gasket replaced by a dealership last winter after oil was found around the spark plug in cyl #1 after misfire CEL, didn't make a difference to oil consumption.
Not sure whether PCV is worth a try...
19389 is offline
