Hesitation on Acceleration - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 20 (permalink) Old 04-09-2011, 07:16 PM Thread Starter
Hi I have a 2004 mazda 6 has 112k miles on it just got done replacing engine and I am having issues when accelerating when its below 2k rpm it has a hesitation when I step on the gas. its not throwing any codes and the idle sounds a little off. when i start it its at 1.2-1.5k when I step on the gas it will drop to 800-900 rpm and bounce back and forth. I have changed plugs and wires the guy that replaced the motor was a friend of a friends and might have messed with the timing Any suggestions?
Kezumel is offline
post #2 of 20 (permalink) Old 04-11-2011, 12:10 AM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
sounds like a vac issue.
flipper66 is offline
post #3 of 20 (permalink) Old 04-11-2011, 02:31 AM
shawnu's Avatar
Mannn. Iv got just about the same thing. Is it a MTX? Below 2k it feels like its bogged down. Iv checked for leaks and what not and still the same. I may have missed something though... Ive done plugs, cleaned MAF, new battery(mine tested bad) and new air filter. Next is wires. Any suggestions for wires/whats wrong with my car anyone??
SOLD::2004 steel gray metallic 6i mtx 103k mi. Advance timing mod. Clutch sensor mod. exedy stage 1 clutch. Exedy flywheel. Green city lights
RIP::2006 dodge ram 1500 QC 2wd hemi 92K mi nightrunner edition. Kenwood x595 HU, kicker750.1 12" kicker L7, Mopar cold air intake. Aftermarket exhaust.
Current::2005 silverado ext. LT 23K mi. blose. leather. flowmaster 50series. linex. Folding hard cover. Excelon shallows on kicker750.1
shawnu is offline
post #4 of 20 (permalink) Old 04-11-2011, 03:27 AM Thread Starter
its a 2004 mazda 6 2.3l I have done the wires plugs cleaned the Maf and checked for vacum leaks. Im taking the engine back to the junk yard and getting a rebuilt motor hoping that fixes the problem.
Kezumel is offline
post #5 of 20 (permalink) Old 04-11-2011, 07:50 PM
Do you have the AC on? That sucks up some horses and causes a slight hesitation upon acceleration.
Warmacblu is offline
post #6 of 20 (permalink) Old 04-12-2011, 06:16 PM
Hi, I bought an 04 mazda 6 IS 5-door in December and I noticed it had some acceleration problems and kinda felt like it was lugging at Lower speeds! Read several forums and ally of ppl said the throttle body, but what I tried, was replacing the 2 cam-shaft position sensors( about $35 for both and takes literally 10 mins to change yourself)! Car now runs amazing and gained about 7 mpg's! Try this and let me know if it helps please!
Bradnc9461 is offline
post #7 of 20 (permalink) Old 04-12-2011, 11:28 PM
shawnu's Avatar
Where did you get the sensors? And could you put up a pic of where they are located? Now i remember A guy at autozone was tellin me something about that. I havent been gettin the greatest mpg either. Thatd be awesome if that 35 dollars does the trick.
shawnu is offline
post #8 of 20 (permalink) Old 04-13-2011, 09:35 AM
actually mine is the 3.0, but im certain they are in the similer location, inline engine, so they would be on your left if youre facing the engine, one on the front cam and one on the rear, if you google your make and model and search for cam position sensor for ex. 2004 mazda 6 2.3 or 3.0, it'll show you where to find them. Nobody carries them, but they can get them overnight. Autozone actually showed me the location on the car, and which one i needed. If you stop by there, you can get your part in a day or so, and get it changed out in no time.. Very Very simple to change, one bolt and one wiring plug. i didn't have to remove any covers at all to get to.. Let me know if this helps you.
post #9 of 20 (permalink) Old 04-13-2011, 10:06 AM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
throwing parts at it like cam sensors hoping for something good sounds like an expensive proposition.
The cam sensor on the 2.3L is on the drivers side forward on the valve cover under the engine cover
post #10 of 20 (permalink) Old 04-13-2011, 10:14 AM
cam sensor location!!
The Following User Says Thank You to Bradnc9461 For This Useful Post:
e4w (04-13-2011)
