Engine does not start - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 15 (permalink) Old 04-14-2010, 03:00 AM Thread Starter
I have Mazda 6i 2003 (2.3L I-4), automatic. I was driving yesterday with no probs. When I tried starting it this morning, it did not at all. When I turn the ignition key to the Start position it does not even do any noise, nothing, as if it was dead... I do not know what it could be. I have recently repaired the starter (was functioning ok all the time after), the battery seems to be ok (at least I was told so by car electrician). So can anyone advise me what it could be?
parabellum is offline
post #2 of 15 (permalink) Old 04-14-2010, 09:38 AM
javim007's Avatar
Bad ignition switch maybe??
http://autorepair.about.com/od/troub...s_no-start.htm
The only Good is Knowledge, the only Evil is Ignorance. - Socrates
javim007 is offline
post #3 of 15 (permalink) Old 04-14-2010, 02:28 PM
07Mazda6H's Avatar
Quoted: 16 Post(s)
Lights and radio working?. Check the battery cables.
Heather & Jeff
2007 Mazda6i / Drk Cherry Metallic / 6k HID's /Ventvisors / Smoked front markers / Tinted rear reflectors / '12 Mazda3 antenna -- Traded in ..8/20/12. </3
2013 Mazda CX-5 : Sky Blue - Moonroof/Bose package - Technology package
07Mazda6H is offline
post #4 of 15 (permalink) Old 04-15-2010, 12:02 AM
MrTea's Avatar
Quoted: 38 Post(s)
like he aluded to, we need more info.
does anything work like lights? was there a gauge sweep when you turned the key? check the voltage on the battery? did you try to jump it?
MrTea is offline
post #5 of 15 (permalink) Old 04-15-2010, 01:58 AM Thread Starter
Both were working. I managed to get it started yesterday evening. After I turned key to the start position, it took engine 2-3 secs not to react and then it started. Still the check engine light was on. Today it was already off. Anyway, I'll get it to the service on Saturday.
post #6 of 15 (permalink) Old 04-15-2010, 02:12 AM Thread Starter
Everything worked: lights, radio, dashboard. It never sweeps gauge and this time neither. Didn't have another battery around to jump it. But I checked my battery last week, it was ok. The thing is that the engine did nothing, not a single sound. I was advised by someone, it could be immobilizer malfunctioning.
post #7 of 15 (permalink) Old 04-15-2010, 10:34 AM
Wow, what are the odds of that.
I have the same problem. Began yesterday. Car wouldnt start and still isnt starting.
The key light flashes in the display cluster once I try to turn the ignition.
Suspecting it's immobilizer malfunction as well or a sudden loss of recognition of my key by the ignition.
I'm stumped. Any ideas?
nijaboy is offline
post #8 of 15 (permalink) Old 04-15-2010, 11:13 AM Thread Starter
"Security" or Key-shaped light flashes on the dashboard - Many cars these days are equipped with an immobilizer. (you can find more information about the immobilizer in your owner's manual). The immobilizer allows the engine to run only if the correct key is used. If your car has an immobilizer, you probable see a "Security" or Key-shaped light coming on on the dashboard every time you turn the ignition ON. If this light is flashing when you turn the ignition ON, it could mean that there is some problem with an immobilizer or the system does not recognize the key. If the immobilizer doesn't recognize the key, the engine wold not start at all, or would start and then die in few seconds. You can try a spare key, if it won't work, your dealer is the place to call. Sometimes, the key is just need to be reprogrammed. On some cars you can find the information how to reprogram the key in the owner's manual.
source: Car no-start troubleshooting guide
post #9 of 15 (permalink) Old 04-15-2010, 11:56 AM
I'd start with simple step: battery. I mean in your pocket key battery, not that under the hood
Oldman is offline
post #10 of 15 (permalink) Old 04-18-2010, 08:12 PM
Found out the coil by the ignition went bad.
nijaboy is offline
