Old 11-11-2009, 12:02 PM   #1 (permalink)
I saw this on a site from an ad on this forum and it's very affordable, and looks like a standard short intake. Does anyone know why it is called an induction kit? Or why it's cheap? Or what that extra hose in the pic is?
K&N 57i Performance Induction Kit p/n 57-0615
http://mazdatune.com/proddetail.asp?prod=K...615&cat=104
Carlb328 is offline   Reply With Quote
Old 11-11-2009, 03:10 PM   #2 (permalink)
slinger4889's Avatar
Send a message via AIM to slinger4889
I think the way it works is that second hose acts sort of like a ram air, bringing air up from the bottom of the engine bay to the intake. I have the proper intake from K&N and am very satisfied with it. I'd look around a bit more before buying this one. Try to find a AEM intake possibly, or you could even buy one of those really cheap Ebay intakes and swap out the filter for an AEM dryflow filter, its up to you.
2005 Pebble Ash 6i ATX K&N SRI, Optimized TB, grounded tb, blue 194's inside, Audiolink Ipod Integration, RPM smoked LED reflectors
"I'm gonna quote the late, great colonel Sanders who said, 'I'm too drunk to taste this chicken"
"Fuck trees I climb buoys motherfucker!"
Yay! I actually went to the strip. . .16.58 @ 82.62
slinger4889 is offline   Reply With Quote
Old 11-11-2009, 03:22 PM   #3 (permalink)
ttshark's Avatar
If that extra pipe at the bottom is a flex-pipe then this intake would have alot of drag compared to other competitors. I'm pretty sure this intake is also only 2.5" in diameter whereas other higher priced kits are 2.75" (CP-E being 3") yeilding better responses.
As said above, a more effective yet still cheap solution is to buy some el cheapo one off ebay and replace the filter since it is basically the same thing as higher priced ones. (eg. Bomz CAI)
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression
Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob
Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel
Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune
ttshark is offline   Reply With Quote
