Old 11-10-2009, 02:00 PM   #1 (permalink)
MZR-6i's Avatar
Send a message via MSN to MZR-6i
does any one have a part number for a thermostat? i need to replace mine.....thanks
04 6i HB, JDM EVO VIII style wing, espilir ASD springs, tokico shocks, customed single exhaust, Scat procar racing seats, Fujita Short RAM, Nex-O GS-5 wheels, Nexxen N5000 tires 225-40-18 (note*) these are not all my mods.....
Bodykits
Team Xplizit
Cardomain Page
ap-auto.com
sponsored by: Six Feet Deep Clothing Amsoil Odyssey batteries
MZR-6i is offline   Reply With Quote
Old 11-10-2009, 02:26 PM   #2 (permalink)
MrTea's Avatar
i'm sure i can find it, but just hit up someone that works at the dealer or Sheldon, as there isn't an aftermarket option, it's a mazda part.
Old 11-10-2009, 09:54 PM   #3 (permalink)
Send a message via MSN to Garry68 Send a message via Yahoo to Garry68
While we are on the subject of thermostats.......do any of your guys know if there are some lower temperature thermostats available? In Malaysia, the JDM stocker appears to be around 93C (200F) and I would prefer a 70C option if it is available.
Garry68 is offline   Reply With Quote
Old 11-11-2009, 08:13 AM   #4 (permalink)
ttshark's Avatar
QUOTE (Garry M6 @ Nov 11 2009, 01:54 PM)
While we are on the subject of thermostats.......do any of your guys know if there are some lower temperature thermostats available? In Malaysia, the JDM stocker appears to be around 93C (200F) and I would prefer a 70C option if it is available.[/b]
Twowheelin makes a low temp thermostat that kicks in at 82.2C (180F). I couldn't see it listed on his website but when you click "order form" it shows up as a product for purchase.
Check it: http://cordovamotorsports.com/
Edit: sorry it is there. Just click "Automotive Electronics" in the Products section.
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression
Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob
Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel
Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune
ttshark is offline   Reply With Quote
Old 11-12-2009, 03:24 PM   #5 (permalink)
MZR-6i's Avatar
QUOTE (ttshark @ Nov 11 2009, 08:13 AM)
Edit: sorry it is there. Just click "Automotive Electronics" in the Products section.[/b]
good looking out..i guess i 'll check it out..now the real issue is trying to install it.......
Bodykits
Team Xplizit
Cardomain Page
ap-auto.com
Old 11-12-2009, 11:45 PM   #6 (permalink)
MrTea's Avatar
it turns the fan on sooner, easy install as well
Old 11-13-2009, 06:57 AM   #7 (permalink)
ttshark's Avatar
QUOTE (MrTea @ Nov 13 2009, 03:45 PM)
it turns the fan on sooner[/b]
Yes that's true. I should have stated that it is not actually a thermostat replacement of any sort, simply a secondary 'switch' to the radiator fan.
