#1 (permalink) | |
QUOTE (eastside6 @ Oct 14 2009, 05:47 AM)
Advanced timing in addition to this would then make it worse? For the first time I am truly appreciating the need to tune my car.
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
where's the link to the dyno...need to see at what point those levels were hit. if it was at 15.0 with a sniffer sitting in 1 pipe of a split exhaust....ehh, really depends on the whole graph, not 1 number.
He has not provided the graph yet. I am just wondering if 'generally' being lean should be expected with intake modifications.
I would imagine our EMS is smart enough to compensate, however I put preservation of my engine over optimism ps. is your car up and running yet?
they car always runs....it just doesn't drive, if that helps.
an intake will almost always lean out the A/F, which is how it makes power. if you go in to tune the car, they typically will be pulling more fuel across the map that they will be adding any...that's where much of the power comes from outside of timing.
