i have to replace my motor in my 6 and i found a short block off of cosworth and i just wanted to know if it would bolt up
You will also hafta run a cable for the throttle body since the Duratec's are cable acctuated TB's and the Mazda MZR engines are electronic
Back from outer space |
Cosworth you say? Aren't those like 10 grand plus? Unless you are actually creating a N/A racing engine, I would look used. You also would have to make a special car brain to run everything, hence why the previous comment on trying to get it to run.
2004 Mazda 6i GT ATX (currently 108,000km) Currently on: Tokico HP shocks all around, Spring Tech lowering spring (F1.7,R1.6), Short Ram intake Edmonton, Alberta Canada |
#5 (permalink) | |
QUOTE (MaverickX3 @ Oct 26 2009, 01:44 PM)
umm, wow....that is some list!
that car sounds destined for failure from the sound of it? maybe 1% of the 6i's on here have had any one of those issues, let alone a combination or ALL of them! what's wrong with the engine? currently running and going out or is it dead already? what happened to engine #1, why the ecu changes (what were the problems)? figured i'd ask before i just said take the hit and sell it for scrap
#7 (permalink) | |
QUOTE (MrTea @ Nov 3 2009, 11:20 PM)
#8 (permalink) | |
QUOTE (brettfessler @ Nov 3 2009, 11:36 PM)
Oh yea i DO own a Mazda don't i!!!!!!!! |
