Old 09-25-2009, 03:04 PM   #1 (permalink)
Thumbs up
Hi, I own a 03 Mazda 6i 2.3L w 123,XXX miles on the it and I've been getting this shaking from the engine bay that transfers over to the inside of the car when ever I take off from a light it. Some days is worse than others it usually last to about 2500 rps then it stops so I took it in to get some work done at a mazda dealership and they told me that I need it a new motor mount. Well I was wondering what are some good after market motor mounts that I can buy. Thanks
Nskylinerb-25 is offline   Reply With Quote
Old 09-25-2009, 05:08 PM   #2 (permalink)
Send a message via AIM to osajek
Right now the only mount that works for us is the one offered by streetunit. 6s motor mount the only thing is that you will have to add a washer to the front of it to close up the gap as well as bending the connector on the subframe so the mount will slide into it. It will all make more sense once you get under there and look at it. I would def. recommend getting the "soft" option if you want to stay close to stock. Changing the mounts generally leads to more in cab vibrations.
Mods: Seibon TM Carbon Fiber Hood, B&M Transmission Cooler, Tein H Techs, 6000k apexcone hid, AEM short ram intake, f2 step header, optimized throttle body, Magnaflow Catback exhaust, spin-on coversion, BSD, oil pan baffle, racing beat rear and front sway bars, awr front endlinks, racing beat rear endlinks, debadged, audiolink ipod, accolade grill, cx-7 antenna, advance timing mod, steeda throttle body spacer, street unit wishbone mount, awr passenger side mount, awr transmission mount, blacked out rear reflectors, smoked side markers, blacked out headlights, scan gauge MY GARAGE
osajek is offline   Reply With Quote
Old 09-25-2009, 08:51 PM   #3 (permalink)
MrTea's Avatar
AWR just released theirs on their site as well. the VF one will fit the '03 without issues, CPE's is the same as SU, just need to add washer to the V6 mount...plenty of options.
