Old 09-21-2009, 11:04 PM   #1 (permalink)
h20eweup2's Avatar
i have these two CEL codes: p2187 system too lean at idle speed and p2004 intake manifold runner stuck open control bank 1. i looked at the thread with the CEL and didnt see either one. my question is could these two vacuum hoses being split be the cause of the cause of the CEL? they are hissing while the engine is on.
the arrows are pointing to where each one goes to/from.
h20eweup2 is offline   Reply With Quote
Old 09-21-2009, 11:20 PM   #2 (permalink)
javim007's Avatar
Most likely yes...but change them, and if the problem persists,there may be more leaks. GL
The only Good is Knowledge, the only Evil is Ignorance. - Socrates
javim007 is offline   Reply With Quote
Old 09-22-2009, 04:10 AM   #3 (permalink)
MrTea's Avatar
those will definately be the issue, the line on teh right controls the VLIM actuator, so that's why you have the same code i do for that one, and the rest is just unmetered air.
neither item is going to kill the car or anything, but it will be a lot happier once they are fixed.
