I recently installed an AEM CAI on my '05 mazda 6. I forgot to d/c the battery during installation so I took it off the terminal for about 3-4 to let the computer reset and do what its gotta do. At first when idling my rpms would fluctuate roughly between 500-800 and frequently stall, needless to say the CEL came on. Ive been driving it about a week since and a couple hundred miles. I don't stall anymore when idling but my rpm's still fluctuate although not as badly and as frequent; the CEL is still on. I have inspection in a couple months and I would like to get some suggestions on what to do. thanks.
Could be a few things. You should always disconnect the battery, so there is the possibility that the MAF sensor short circuited depending on how it was removed. Also, could be that the VAC hose is loose on either end causing the uneasy idle.
You may also want to try the Advanced Timing Mod. This may resolve rough idle as it seems to do with many. On a side note: someone correct me if i'm wrong but isn't the AEM CAI the one that has the MAF sensor down near the wheel well? If it is then from my experience, it is simply because of the way the CAI is designed. Input on this please.
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
#3 (permalink) | |
QUOTE (ttshark @ Sep 19 2009, 09:35 AM)
Yes the AEM cai has the MAF right above the filter by the wheel well |
i would do this:
-go remove the battery terminal -re-check the install to ensure there are no loose/open vacuum lines, as that's the biggest issue typically -connect the battery and stay away from cruising speeds if possible. go flog the car for a few 10-15min stints then park it, go do it a gain a bit later. the CEL is from being lean at low loads, nothing else, so the issue tends to pop up when cruising down the street and letting off the gas. if you put it into neutral and coast you won't have the same issue either. so i just suggest trying to stay out of that situation for a few days if at all possible while the ecu relearns things. if the CEL comes on, 99% of the time it won't go off on it's own...so no point in waiting. ...on a side note, when was the last time you had the car at the dealer and the ecu flashed? typically the newer flashed eliminated the issue we all used to have with this when the intakes first came out. again, could just be a loose hose or something, but throwing out all possibilities.
#5 (permalink) | |
QUOTE (MrTea @ Sep 19 2009, 12:35 PM)
What is the newest ECU flash? Mine was done like 2 years ago.
Link to the Yellow Submarine [2003 Speed Yellow]... Come join the flickr group! http://flickr.com/groups/atenza/
#7 (permalink) | |
QUOTE (nickd @ Sep 18 2009, 12:45 PM)
#8 (permalink) |
there was a flash in '05 i believe that helped the early guys get over the intake CEL issues, and the '05+ cars don't have issues with them. i think last time i was flashed was like nov '04 or feb '05, can't remember. i've had like 5 pending codes for the last 3 years though, just painted over the CEL in the dash so i don't see it.
easiest way to check the MAF for sure is to meet up with a guy and swap them, see if the issues follows the MAF or the car.
