Old 09-13-2009, 03:15 PM   #1 (permalink)
http://www.focussport.com/cosworth-manifold.htm
this intake manifold and the cams that are for the 2.3 duratec. ford makes the motor thats in our cars so it should work...right?
mtosofsky is offline   Reply With Quote
Old 09-13-2009, 05:23 PM   #2 (permalink)
pray4mojo's Avatar
QUOTE (mtosofsky @ Sep 13 2009, 12:15 PM)
this intake manifold and the cams that are for the 2.3 duratec. ford makes the motor thats in our cars so it should work...right?[/b]
i think the TB is different so youre going to need to tap your own holes.
2006 Onyx Black MTX 6i
its got some rims and some blacked out stuff..
pray4mojo is offline   Reply With Quote
Old 09-13-2009, 05:41 PM   #3 (permalink)
Send a message via AIM to Sokool
As he said the TB is different so it requires a drilled and tapped hole to fit the mazda one. Also it deletes the VIS and VTCS you will have to leave the solenoids hooked up to keep from getting a CEL.
As far as cams the trigger wheels on the Mazda has 6 teeth and the Ford only has 1. So short of going full stand alone and negating the need for 6 teeth you can't get the focus cams to work.
Sokool is offline   Reply With Quote
Old 09-13-2009, 08:49 PM   #4 (permalink)
Business's Avatar
QUOTE (mtosofsky @ Sep 13 2009, 01:15 PM)
Incorrect.
The Focus/Fusion/Milan/etc have the Duratec23, the Mazda3s and Mazda6i have the 2.3l MZR and the MZR came first, being the basis of the Duratec23, not the other way around. VVT is found in the Fusion and Milan Duratec23 but not the Focus.
In regards to the cosworth manifold, you'd need to cut a little bit of the left-most part of the manifold in order for it to fit, since the power steering reservoir is unfortunately located there.
Also, one or two Mazda3 guys have put Crower stage2 cams originally designed for the Focus in their 3s without a standalone. Just takes some work.
Now rocking a 91 Miata
Old 09-13-2009, 10:43 PM   #5 (permalink)
QUOTE (Business @ Sep 13 2009, 08:49 PM)
Also, one or two Mazda3 guys have put Crower stage2 cams originally designed for the Focus in their 3s without a standalone. Just takes some work.[/b]
Proof?
Cause I know of only one guy with cams and he is full stand alone making 500+ WHP. He has my old mani and downpipe. I came from a Mazda3, I followed all of this with a passion.
Old 09-13-2009, 10:58 PM   #6 (permalink)
ro4fd's Avatar
Send a message via AIM to ro4fd
QUOTE (Sokool @ Sep 13 2009, 09:43 PM)
Proof?
Cause I know of only one guy with cams and he is full stand alone making 500+ WHP. He has my old mani and downpipe. I came from a Mazda3, I followed all of this with a passion.[/b]
Black Se dan?
04 Volcano Red Hatch
ro4fd is offline   Reply With Quote
Old 09-13-2009, 11:10 PM   #7 (permalink)
MrTea's Avatar
on of the guys on M3F has had them for a while now, forgot his name, he's done a lot of crap over the years now. he's the only one i know of though....never paid attention to the ecu though.
Old 09-13-2009, 11:21 PM   #8 (permalink)
His name is amnizer here is his build thread.
http://www.mazda3forums.com/index.php?topic=136349.0
