Old 06-02-2009, 12:52 AM   #1 (permalink)
MrTea's Avatar
This will be an evolving thread, but should provide enough info that we won't have a new thread every other day asking the same questions. Please bare in mind that the info provided is based solely on my experience and opinion. Please take the info i have and use it as you will, discuss the project with your local shop/tuner/dad/brother and move forward from there. Anyone with more info please feel free to give input, but i will be cleaning this thread up as it goes, so please don't bitch.
Q: What are my options for turbo'ing my 6i?
A: The options vary currenlty. there are 5 standard answers, most can be googled for more info
1) HiBoost
2) F2
3) HASS (via turbokits.com)
4) built using Mazdaspeed6 parts
5) depending on where you are, a TRUST (Greddy) kit is available, though tuning has yet to work in the states, as well as fitment issues with LHD models.
Q: Do I need to build the engine? what boost can i run "safely"?
A: The stock block has been pretty good on about 8psi on pump gas. Anything more than that the bottom end should be addressed
Q: What about the tranny, i have an ____ (insert MTX or ATX)?
A: both tansmissions will be fine.
1- The stock MTX has a tendancy to sheer 3rd gear at times (no specific power level, just some last and others don't)
2- Both 4 & 5spd ATX trans also work, though it's recommend to run 6psi on these setups. also, an additional trans cooler is essential as well for the atx.
Q: Can i make my own, i found a good kit on ebay?
A: sure, have fun, don't cry when it doesn't work right and cost more in the long run!
Q: How much can i expect to pay?
A: Quick answer is have $5k ready to spend, or don't think about it. Now, it depends on the kit obviously. F2's stage1 will be the lowest price KIT, and HASS ranges up to $4300 i believe. You can make your own Mazdaspeed'ish setup, but it is not a kit, so prices will vary and you'll need to find your own tuning solution. The install is amazingly easy in these cars, the install would range in the 5-8 hour range if you are looking at a shop. Most KITS will come with a tune to get you started, though it's recommended to to dyno tune your specific car, which is roughly a 2 hour job, though doesn't really need to be done ASAP.
Q: What else do i need to buy?
A: If it's a true kit, then nothing! There are items to make it better, make it last long and obviously make more power....but they aren't needed. Things i would recommend you have on our short list however, as they will aid with tuning and safety.
1- a WIDEBAND (no, the narrowband you saw on ebay won't work) Air/Fuel gauge, this is a must for tuning
2- spark plugs (i REALLY like the Autolite 103's, especially in the beginning while tuning. They are UBER cheap, and work well, easy to gap also)
.....that's it, for the long list i'd add:
3- oil temp OR pressure gauge (dont' see the need for both, and no your stock gauge doesn't do anything. this is only to see problems sooner, nothing else)
4- boost controller (DO NOT ADJUST BOOST!!) A boost controller will aid in how the boost comes on and levels off, feels much better. i suggest a manual controller in the engine bay that you CAN'T touch while driving)
.....There are other things, but they are not turbo related, they are performance related. (things like limited slips, clutch/fly, better rubber). you DO NOT need a turbo timer if you have any common sense, you can, but you are just spending money.
This is all the basic info on the setups that i could think of. For the most part, an 8psi intercooled kit on a STOCK 6i MTX in the 225whp range, the ATX (6psi) at just over 200whp. Power will be increased with an exhaust, which most have anyhow, but it's not needed to enjoy boosting.
notes for the ATX guys:
'03-'05 6i's with the 4spd have an off the shelf option to upgrade both their valvebodies and torque converter from Lentechautomatics.com, or whole tranny if you'd like. The valvbodies help out an amazing amount, and allow for a bit more boost if you want, the converter allows for a higher stall speed which is nice if you powerbrake often (the strip) and they can also remove the lock-up setup which can be a bitch when having fun on highway cruising.
'05+ 5spd ATX's have faster/tighter shifting out of the box, so that is a nice start. If valvebodies are something you want (as they can be improved quite a bit), Levelten.com has experience with them, though you need to remove yours and send it to them for the work.
Both models- please take a minute to understand how your ATX works, and then understand why i say you should always let your foot off the gas between WOT shifts. It is not something that will brake the tranny in one time, but please understand it's not recommended as the boost is still being applied while the tranny is trying to shift. Also, for the same reason, if you are cruising on the hwy while the converter is in lockup, DO NOT just slam it to the floor, it's not good for it either, a quick blip or downshift will safe a lot of trouble.
Now, i know of roughly 6 turbo'd 6i's that are (or have been) daily drivable, there are currently 4 on this forum actively i believe (as of 6/09). I would imagine all would attest that it's a friggin blast to drive, and the smile doesn't leave your face! The car is still pretty light at just over 3k, so the addition of 80-90WHP (about 60%) makes a huge difference in feel. But keep in mind that it costs roughly $5k on the low side for the setup, which is anywhere from 25-50% of what the car is worth, premium gas is required now, and it's hard to go back to stock if you think it's temporary. In the 4 years i've been turbo'd and talking to people about it, i've found that if your plan is more than 6 months (it's more like 3-4) out, then you won't get it. If you have 90% of the money in hand and are serious, go for it, but if not, there's not need for a billion questions that don't go anywhere, please just read what's on here already and enjoy the dream (it's cheaper!)
This link will always show you all the current topics for turbo's on the 6i's:
Turbo threads
here's a few vids that have been around forever, but if you are new you might like them.
Old 06-02-2009, 04:00 PM   #2 (permalink)
Shane23's Avatar
Send a message via AIM to Shane23 Send a message via MSN to Shane23 Send a message via Yahoo to Shane23
Very Well Done...
Wow, how long has that F2 kit been up there...?
also are Motor Mounts a Neccesity or NO..?
| 2005 Mazda 6i (Performance White) |
| My Mazda6 TimeLine |
Shane23 is offline   Reply With Quote
Old 06-02-2009, 04:05 PM   #3 (permalink)
Wolf 10's Avatar
Send a message via AIM to Wolf 10
Great post, this just might sum up the hundreds of posts regarding turbos (MAYBE). That F2 stage 1 turbo caught my eye. Not a bad price for a turbo although since I probably wouldn't be installing it myself that number increases dramaticly =(.
ATX 2006 Mazda 6i (silver) Bomz Short Ram Intake w/ K&N filter, Optimized Throttle Body w/ Steeda Spacer, F2 Step Header w/ high flow cat & Magnaflow Cat-Back Exhaust System, 35W H1 XENON HID 5000k, Super White LED 194's
Wolf 10 is offline   Reply With Quote
Old 06-02-2009, 04:46 PM   #4 (permalink)
Lenn's Avatar
Nice write up man. Must have gotten sick of all them PM's and pipe dream threads. Thanks for the vids as well.
SEMPER PARATUS
2007 Mazda6i SVE- JDM Yellow fogs, Brake light mod, CX7 Antenna
1992 Dodge Stealth RT/TT- Greddy Type-S BOV, Boost mod, Airbox delete, gutted pre-cats... more to come.
Lenn is offline   Reply With Quote
Old 06-02-2009, 06:35 PM   #5 (permalink)
xxxmonoxidechild's Avatar
Send a message via AIM to xxxmonoxidechild
turbokits.com doesnt list any turbo kits for our car's. just bolt up turbo upgrade's for the speed6's.
do they just not post about the kit, or did they stop selling it?
xxxmonoxidechild is offline   Reply With Quote
Old 06-03-2009, 12:55 AM   #6 (permalink)
Business's Avatar
Thank you.
I doubt this will stem the flow of turbo threads, but nice job anyways.
Now rocking a 91 Miata
Old 06-03-2009, 04:20 AM   #7 (permalink)
MrTea's Avatar
if you google "HASS turbo mazda6", you will be led to the turbokits.com site. it's no longer listed, but they were the ones that took over the setup from HASS originally, so if you want it, it's the only place that may be able to get it for you. The HASS kit was the best produced kit in regards to fit and finish, it truely was beautiful, bends, piping, fittings, sizing....all of it. BUT, I had one of the member here take his car in for the design of the kit, and after a year the car still wasn't driveable, lots of issues with the Emanage, so i've always recommended their kit sans tuner and find your own option.
engine mounts fall into the performance mod range, nothing to do with the turbo. The kit will act absolutely no different with or without upgraded mounts. They are nice, but some don't like vibrations, some don't notice it, some want hard, some want soft....but none of those things have to do with a turbo. they are more for shifting feel and car balance a bit, as when you get on or let off the throttle quickly, there is less weight transfer.
thanks for the input, i'll try to update more info as i think of stuff, this was a 15min thing before i left for work today.
Old 06-03-2009, 11:47 PM   #8 (permalink)
Send a message via MSN to Garry68 Send a message via Yahoo to Garry68
Nice write up Mr. Tea. It's about time we had a turbo kit sticky in the forum and long overdue I think.
Garry68 is offline   Reply With Quote
Old 06-04-2009, 03:27 PM   #9 (permalink)
m6racer's Avatar
Send a message via AIM to m6racer
nice writeup tea. hopefully the "i think i want to turbo my 6i" threads die down now.
Chris's 03 Speed6i
my cardomain
m6racer is offline   Reply With Quote
Old 06-13-2009, 01:03 AM   #10 (permalink)
id recommend anyone wanting one to wait for F2. HIBOOST or their distributor here in the US TBK Performance will lie to you every step of the way. they will tell you a 4-6 build time which turns into atleast 6 months. and youll go through a hell of a time to get your money back. so if you do; dont pay in full. you might not ever see anything
AutoX Run
werm9 is offline   Reply With Quote
