Changed Brake Pads and Disaster HELP!!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 03-05-2008, 03:55 PM   #1 (permalink)
Send a message via Yahoo to josh04m6
ok i changed the brake pads and the back two rotors, anyways i get all done and i have no brakes at all....i did take the front calipers off to check the brake pads which i did replace i get all done get my car off the stands and then i have no brakes and i have to put my car at 4K RPm to move 12 inches while in reverse and when in drive i dont move at all, hit rev limiter for 3 seconds and didnt go anywhere with the car in drive.....when im sitting in the car i push the brake pedal and it goes all the way to the floor...i have brake fluid and transmission fluid and my transmission was fine before i did the brake pads which i thought would mean that i screwed up somewhere...only problem is that i dont know where i screwed up and i need some help.....any help or suggestions are greatly appreciated....
the car is an 04 6i AT spin on conversion, intake, ehaust
nothinspecial
2004 M6i ATX, Intake, Exhaust, NGK Iridium Plugs
josh04m6 is offline   Reply With Quote
Old 03-05-2008, 03:56 PM   #2 (permalink)
Did you bleed your brakes?
My Car
Indy MPS6 is offline   Reply With Quote
Old 03-05-2008, 03:56 PM   #3 (permalink)
nothinspecial[/b]
Did you bleed them?
publicsrvr is offline   Reply With Quote
Old 03-05-2008, 04:11 PM   #4 (permalink)
um no i didnt not really sufre how?? will not bleeding them cause my tranny not to catch??
Old 03-05-2008, 04:50 PM   #5 (permalink)
twowheelin's Avatar
Basically you have lot's of air in your hydraulic brake system. (That's what happens if you remove a caliper or open any of the brake fluid hoses....) The computer wont let the tranny out of park if you don't have pressure on the brakes, so your car isn't going anywhere without a pressurized brake system. You need to completely fill the brake resevoir, and then bleed each of the 4 brake lines.
- To bleed the brakes, locate the bleeder valve on the caliber and slip a 1/4 vacuum hose over the nipple.
- Dangle the other end of the hose in a jar with with enough brake fluid in the bottom to submerse the hose end.
- Now loosen the bleeder valve open about 1/2 - 3/4 turn making sure the hose stays attached to the nipple ane the end stays submersed in the jar.
- Start the car and slowly press the brake pedal to the floor 10-12 times.
- Check the brake resevoir to make sure it doesn't empty, refill, and put the cap back on as needed.
- Keep pumping the brakes until the fluid gets pumped into the jar with no bubbles.
- Re-tighten the bleeder valve, move the the next wheel, and repeat...
- After doing all 4 wheels you brake pedal should be firm and high when the brakes are applied.
- If the pedal still sinks, you have air in the lines or a brake fluid leak somewhere....
I would recommend a book that explains the proper procedure for doing this to ensure you do it correctly. If you don't understand what's going on, tow your car to a mechanic or brake shop and get the job done professionaly. You don't want to lose your brakes!!!
03-6i ATX: Hawk ceramic pads, SS lines, PowerSlot Rotors, Tanabe-NFs+Konis, Kosei K1-TS, Spin On Conversion, Custom CAI/MAF, 2 1/4" Exhaust, Optimized TB, Adjustable Fan Controller CordovaMotorsports.com (An RPM Customer!)
twowheelin is offline   Reply With Quote
Old 03-05-2008, 05:29 PM   #6 (permalink)
well i just finished the bleeding them and everthing is ok disaster resolved thank you very much everyone that decided to post.....
Old 03-05-2008, 11:51 PM   #7 (permalink)
ok i had a relapse the bleeding either didnt work or i didnt do it right i followed your directions completely 100% and no go so maybe that wasnt the problem....i have another question is i reset the ECU by disconnecting the battery will the ECU recheck the brakes and see that they are fine and let my tranny engage or do i just need tranny fluid or ned to drain and flush it??? i never did anything with the tranny so i dont know why that would be the problem,
QUESTION : If i reset the ECU could it possibly fix the problem? if not any suggestion is worth a try at this point..
any insight is greatly helpful even if u think it is awaste of time it COULD work so lemme in or ur thoughts plz!!
Old 03-06-2008, 12:05 AM   #8 (permalink)
I would recommend a book that explains the proper procedure for doing this to ensure you do it correctly. If you don't understand what's going on, tow your car to a mechanic or brake shop and get the job done professionaly. You don't want to lose your brakes!!! [/b]
dude you are the man....I would've had no clue about that....no clue.
-'06 2.3 6i mtx-
grhandley is offline   Reply With Quote
Old 03-06-2008, 12:10 AM   #9 (permalink)
karlt10's Avatar
No, resetting the ECU won't do anything to the brakes. Then again, if you didn't physically remove the lines to the calipers, or open the bleeders the first time around, bleeding the brakes wouldn't have helped either. I've changed brake pads countless times without bleeding the system - it was fine every time.
Did you actually remove the brake lines from the calipers or open the bleeders the first time around? What you describe about the pedal going to the floor sounds like air in the system...
And nothing with the brakes should affect the tranny at all...... you certainly don't need to change tranny fluid.
What EXACTLY did you do when you worked on the brakes? Something isn't adding-up here.....
MazdaSpeed springs & sway bars / Bilstein / Racing Beat end links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & Redstuff pads / StopTech brake lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Redline D4 fluid
Mazda iPod adapter
/ CX7 antenna
Yokohama Avid Envigor / Bridgestone Blizzak
karlt10 is offline   Reply With Quote
Old 03-06-2008, 12:23 AM   #10 (permalink)
*ICE*'s Avatar
theres a guide on www.mazda6tech.com that show you how to bleed the brake. Not sure if the site is still up or not anymore...
* Garage*
NO LONGER AN ACTIVE MEMBER OF THIS FORUM. PLEASE DO NOT PM ME. i WILL NOT RESPONSE
*ICE* is offline   Reply With Quote
