hi i have real bad vibrton from my engine i allmost shure this is the engine mount
how much mount there is in mazda 6 and were is Passenger engine mount sit in ? thank you for your help Eric |
Administrator
Hi drive21, can you please tell us what kind of 6 you have? You posted this in two very different sections, one was the Mazdaspeed (MPS) and the other here under the 2.0L. I take it English is not your first language, but it seems you want to know how many mounts there are and the passenger side mount is. Before we can answer that, we need to know what side of the road you drive on!
2004 Mazda6s MTX: Injen/CP-E Tunable, Espelier Lowering Springs, Racing Beat Sway Bars, 6gunrocket endlinks 1988 323 GTX: It LIVES!! |
my mazda is mazda 6 2003 2.0l. and i drive on the left side of the road
so how much engine mount there is ? and were is the passenger side engine mount is ? |
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
Hi, in the case of the 6 with steering wheel in the right 1 mount is locate under the battery, the other very hidden. I will check if I found pictures. But you can also check the pulleys.I had a problem with one of the pulleys a produce a loud noise and vibrations
Mazda 6 (2.0) Automatic. Strato Blue Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs). 2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
#7 (permalink) |
There's two parts one is like a hook and the other is a rubber headed one. i recommend you go to the dealer to change it faster. and just to let you know mazda6 03-05 doesn't have that strong engine mouting against impacts and running over a big speed humps in high speed.
#8 (permalink) |
I'm not familiar with the LHD 2.0, but I would imagine that Mazda would not design different mounts and placemants for it.
That being said in the USDM version there are 3 mounts.One on the passenger side,one for the transmission and a lower mount. The lower mount is usually the first to go as it is the one that takes most of the torque stress.I'd check that one first.
The only Good is Knowledge, the only Evil is Ignorance. - Socrates |
