Hello
Injen CAI + B&M Cooler (for transmission oil ) + GT SPEC Header + MagnaFlow Cat-Back I will install these performanctools on my M6 i Can someone tell me how many horses I will get of each tool ? Because I am going to race someone . He has Honda accord 4 cyl . I don't now what he hide under his hood . Thanks
04 Mazda6 4D 2.0 ATX - Injen CAI - 67mm CFM Throttle Body - F2 Header - MagnaFlow - B&M Tranny Cooler Coming : Cosworth Manifold - Camshaft - Apexi AFC neo then done |
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
Do you have a 2.0?
with the INJEN CAI around 5hp in the 2.0 (10hp with 2.3). The Magnaflow Catback, around 8hp, with a header around 5-10hp.
Mazda 6 (2.0) Automatic. Strato Blue Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs). 2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
#3 (permalink) | |
Yes, I have 2.0 and the honda too . what about transmission oil cooler ? if you don't now it , check this link http://www.bmracing.com/index.php?id=produ...cat=&pid=74 thanks
i'll trust scorpion, since we don't get the 2.0 up here. but in general, a stock dyno with the atx 2.0 is around 118hp, and i'd guess you are somewhere in the mid to high 130's with your setup.
and sorry, the tranny cooloer won't do anything for you in regards to performance.
I am not sure if he has the Automatic or manual. 2003 came from stock with 141hp but in ATX you loose some more Hp than manual Actually they come with 147hp.
i've seen 2 atx 2.0's (actually, both were mazda3's though) on the dyno, one at 118whp and other at 119whp....so that's what i was refering to. i dyno'd at 128whp on my stock 160hp car, so that's about right.
and if he has the tranny cooler, he has to be atx....so that's why it's all i refered to. it's hard to compete against hondas that you don't know....cause you can do anything to them. so i wouldnt' plan on being faster than the guy, but maybe you can keep up?
#7 (permalink) | |
O.K thanks i will try to find something else to get more . and i will compete him then i will tell you who win .
#8 (permalink) |
If you have the money you can go for a Turbo
#9 (permalink) | |
my car ATX and use it daily . i think the tools i mention it are enough and thanks agine
#10 (permalink) |
You have the stock wheels? You can go for a lighter rims and tires. Stock rims/tire weight around 43 lbs (19,5 kgs) you can easily reduce the rotacional weight with a lighter set.
