Hello guys
I have M 6i 2.0 , I am woundring if I can increase the HP to 200 and above tell me guys what I can to do for that , and I use the car daily . Thanks
04 Mazda6 4D 2.0 ATX - Injen CAI - 67mm CFM Throttle Body - F2 Header - MagnaFlow - B&M Tranny Cooler Coming : Cosworth Manifold - Camshaft - Apexi AFC neo then done |
#2 (permalink) | |
Pray.
230whp/280tq Cobb SRI, Cobb TIP, 3" CP-E Single Exit (w/resonator), 3" SU TP, 3.25" ETS, Synapse BPV, CP-E RMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Car-Led Tail-Lights, H&R Springs, Drag DR-33 Wheels |
#3 (permalink) | |
I will
unless you go with a Turbo (or find an SC kit) chances are damn slim to hit 200 on the 2.0
the HiBoost kit will fit on it if you want to go with the turbo also (they've gotten it up to just over 500whp on that engine so far if you want) if you want to stay NA, it is POSSIBLE, but far from daily drivable....and would be very expensive. maybe take a look over at Focaljet.com for some ideas on how they got their engines close to that number.
#5 (permalink) | |
thank you mr tea for the info , but i refer stay NA , another question mr tea what soft things sush as cai i can use it and what is the best ? thanks
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
Ufff with 141hp (2003) or 147hp (2006) will be very hard to reach 200hp,unless you use that MrTea wrote. With Header and CAI maybe you should gain around 16hp or a little less. Some lighter rims/tires will help a little with the acceleration
Mazda 6 (2.0) Automatic. Strato Blue Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs). 2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
#7 (permalink) | |
Thanks MR SCORPION6 and all who share me my problem thank you
