Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > 2.0L I-4
Old 03-07-2006, 02:24 AM   #1 (permalink)
LeM6Boy
Guest
Posts: n/a
Hi all
I have a Mazda 6 2.0HB. Stock, it boosts 150BHP. Yesterday, I was on the highway, some geek with a modified SIR toyed with me. Is the SIR that powerful.
I was wondering whether I can mod mine to 200bhp. any one can advise? What should I do?
Cheers
Old 03-07-2006, 02:42 AM   #2 (permalink)
dabears2k's Avatar
What is a SIR?
Kriegsfeld.com Blog
-G.C. Lichtenberg
dabears2k is offline   Reply With Quote
Old 03-07-2006, 04:16 AM   #3 (permalink)
Administrator
Mazda Gremlyn's Avatar
Probably a Civic SI-R, and to go from 150 to 200... start spending! I'm not very familiar with whats out there for the 2.0 (not the diesel right?), but I'm sure you can dig up something.
Oh and next time, try to find the right section for this....
And also put your location in your profile.
2004 Mazda6s MTX: Injen/CP-E Tunable, Espelier Lowering Springs, Racing Beat Sway Bars, 6gunrocket endlinks
1988 323 GTX: It LIVES!!
Mazda Gremlyn is offline   Reply With Quote
Old 12-23-2006, 11:46 AM   #4 (permalink)
Get a high butterfly oxygen intake valve or cold air intake system
chinese_farmer is offline   Reply With Quote
Old 12-26-2006, 03:58 PM   #5 (permalink)
SCORPION6's Avatar
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
2.0 (2003) 141hp. Come with One Single Exhaust
2.0 (2006) 147hp. Come with Two Exhausts
You are from??
Mazda 6 (2.0) Automatic. Strato Blue
Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs).
2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads
Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
SCORPION6 is offline   Reply With Quote
Old 12-26-2006, 04:04 PM   #6 (permalink)
a troll
100% stock, I don't like mods.
Ryobob is offline   Reply With Quote
Old 12-26-2006, 05:55 PM   #7 (permalink)
J Dragon's Avatar
150bhp on a 2.0 platform, that's pretty damn good.
<span style="font-family:Georgia">06 mazdaspeed6 Sport w Nav --- If it's too good to be true, It's too good for you!!</span>
J Dragon is offline   Reply With Quote
Old 12-26-2006, 11:04 PM   #8 (permalink)
MrTea's Avatar
if you are still reading this, let me suggest checking out Mazda3forums.com as they have a buttload of guys dealing with the 2.0, where as we rarely see them as they aren't in the states where a good majority of the site comes from.
i'm over there too if you have any questions you still can't find. and, depending on where you are and what ecu you have, there is a German (Swede?) company that has an ecu flash/upgrade for you.
Old 01-16-2007, 08:47 AM   #9 (permalink)
Koya's Avatar
Flywheel and clutch are the same as 2.3l
Breakes is same
Exhaust is same (exept headers)
Coswort have forged internals for 2.0 so you will have valves with springs and pistons with rods for rebuild
HiBoost have 2.0 complete turbokit
So... if you really wanna go... there is a lot of possibilities...
2003 Mazda 6i 2.3l MTX - STOLEN
Installed : Clutch Masters FX300 Clutch, Fidanza Aluminum Flywheel, CPE MAFci™ System, Audio Link USB MP3, TWM Short Throw Shifter, Carbotech Brake Rotors, Carbotech Performance Brake Pads (Bobcats), CPE Lightweight Battery Tray, Odyssey PC680MJ Battery, TEIN Hood Dampers
Koya is offline   Reply With Quote
Old 01-16-2007, 09:20 AM   #10 (permalink)
SCORPION6's Avatar
Mazda 6 (2.0) usea a similar manifold than Mazda 6 (2.3). Same Header for both
