Help needed please - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.0 Diesel
New User? Register
Old 11-21-2012, 04:54 PM   #1 (permalink)
Default Help needed please
Hey all I'm new to forums and need some help got a mazda 6 sport and having problems it lost power and used all the oil found out the turbo had a bent shaft and some play in it changed turbo new pipes oil Nd filters
New it still spitting oil into the exhaust and has used 5 litres of oil in 15 miles still loss of power and smoking really bad took the rocker cover off and the oil in top is like jelly and gunk hope someone can help
Phill54 is offline   Reply With Quote
Old 11-21-2012, 06:53 PM   #2 (permalink)
Love Dem Beads
Mr.Smoke's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 773 Post(s)
Sounds like its time for a new engine.
Mr.Smoke is online now   Reply With Quote
Old 11-22-2012, 04:47 AM   #3 (permalink)
This does'nt sound good, the jelly like oil is a sign of lack of oil changes, have you had your oil light flickering on and when you've checked the oil level it's been fine?
Dave
slidey is offline   Reply With Quote
Old 11-22-2012, 02:41 PM   #4 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
So the oil has been changed at least twice in its life? A victim of neglect!
Could have save a ton by doing it every 5000 miles! like said above, it needs a transplant! Good luck!
>79,000
