#11 (permalink) |
Dave,
now I have another problem..."Check Engine" from time to time lights. When it's ON, it stays on for day or two, then it gets OFF. What kind of a problem this can be? Thanks |
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) |
Drozer, you'll need to get the codes read otherwise i'm just grasping at straws, it really could be anything.
Dave |
#13 (permalink) |
Hi Dave,
I've been to mazda service and they told me that the problem was in the Protege Vacuum Switch Valve (96 Mazda Protege Vacuum Switch Valve VSV #K5T49091 KL015905 | eBay). The problem that I had is that "Check Engine" lights from time to time. In the mazda shop told me that this is not a big problem, and that this is a common error of this kind of models. So, can you tell me, the real function of this valve, and how "big" is this problem? Thanks, |
#14 (permalink) |
Hi Drozer,i've never heard of such a switch! i've googled it and it seems to have something to do with the EGR valve, so i've looked in the workshop manual and there is a valve that controls the EGR (EGR solenoid valve).
Have you cleaned your EGR yet? if not i would try that. The valve helps control emissions but can cause running problems if it gets blocked up. Dave |
#15 (permalink) |
I haven't clean the EGR valve yet. Also I have notice that when my car is in neutral speed, and I hit the accelator paddle, there is a little bit black smoke coming out from the EGR valve.
Definitively I'll clean the EGR valve ASAP. Thanks ones again Dave... |
#16 (permalink) |
I just want to say thanks to the forum for saving me a fortune! I have lived with the occasional stall, warm or cold, for perhaps a year. In the last month stalls became progressively more frequent, such that allowing revs to drop below even 1500 rpm would allow the engine to stall, after which re-starting was getting more difficult.
So ordered new Denso SCV from internet (£125), had it fitted (£10) - problem solved! |
Advertisement | |
