Clock module removal - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 02-17-2017, 11:33 AM Thread Starter
2005 Mazda 6: the digital display unit in the center of the dash has failed and I have a replacement unit. What is the procedure to remove and install that unit?
Thanks in advance
mcoley is offline
post #2 of 3 (permalink) Old 02-17-2017, 01:17 PM
waughoo's Avatar
Quoted: 25 Post(s)
It involves taking the radio out first. Search the forum for radio removal and then once it's out the display will be available to remove.
waughoo is offline
post #3 of 3 (permalink) Old 02-17-2017, 06:09 PM Thread Starter
Just learned, by trial, no need to remove the radio. I ground down the end of a paint can opener, pried up slightly on the clock module with my thumb enough to slip the can opener under the bezel and then pried/popped the module out.
mcoley is offline
